Indicators Flashing To Fast
moot
Hey there my supra buddys I'm having a problem with my indicators flashing to fast?? Iv changed the relay-fuses and checked the bulbs but still no luck!! The prev owner had LED side reps but iv removed them and changed the relay and they r still doing it any ideas???
Many thanks....
Welcome to TOC :thumbsup:
Normally as far as I know if the indicators are flashing too quickly there is a bulb blown - by removing the side repeaters this could have the same effect perhaps???
I think you right,
I agree.
If the bulbs that are present are all working correctly (not blown) and they flash, then the relay is fine as it is designed to make the indicators flash.
So the missing bulbs must be the issue. Try refitting them and see if the problem is resolved.
Cheers for ur input guys,
I can't re-fit them as they broke hence had 2 change them so this is where the problem began so I just put in normal side repeaters but even with the LEDS it never flashed properly!! The hazard light flash at the correct speed but just left or right signal is affected so now thinking it could be the relay in the indicator stork????
the flasher relay will be in the dash somewhere,as you have to be able to hear it clicking.dont think it would be in the idicator stalk.
