Steering Wheel Vibration Turning Left And Right
joshau2009
hi please can you help i have a steering wheel judder between 70-80 mph can be felt more if wheel turned slightly to the left of right goes away when wheel straightened i have carried out visual check on the normal suspects and all seem ok any help would be appreciated thanks avensis 1.8 sr 2002 72000 miles on clock
Try braking harsh at 70mph and see if it's more pronounced - if so then it's almost deffo a warped brake disc. If you feel it through the steering wheel and pedals then it's the front.
If not then either bad wheel balance, buckled wheel or bent driveshaft or something more sinister.
start with wheel balance. I had done it last week and funny enough after having it balanced, it started very little vibration, need to take it back to them.
