Gen 7 Info / Advice
viagression
Thanks ormi mate, il check tyres and wheel alighnment, is ther a way 2 check if my wheels are not aligned.I'm sure the spark plugs,fuel,air filter shud all be fine as I had a major service last June and have only covered 4k since. Il check the brakes Aswel, wud u expect the car 2 be pulling 2 one side if 1 brake was catching.thanks again.
turn your wheels on full lock and check how they are wearing they should be wearing even..
fuel filter is part of the fuel pump so thats not been done a lot of garages wont change the plugs as they are very expensive plugs you can pay up to £60 for the plugs...
and yip mate the car will pull to the side the brakes are stuck on....
ok update on op.
the original one i was looking at is gone.
I am looking at one with 170k on the clock, has had a new clutch at some point in its life.
looks mint.
got the black triangle vinyl / paint on the middle of the bonnet. any thoughts again welcomed, also any advice on the specifics of this model,
again its a y reg.
post-106478-0-98679000-1300578416_thumb.
em milage a bit high for me..also illegal tints on the front......
how much you got to spend?
bout 1700, its had a new clutch, and its got long mot.
id hope the tints are within legal limits i am buying from a dealer, so i got come back if its not?
no they arent no tint on the front windows are legal...none at all...its been that was for ages now mate...
