anything i needs to look out for or keep in mind when buying ?
will any 4 stud alloys fit ?
4x100 and et must be 35-42 many rims are 35,38 et
cb 54.1
and tyresize 155/65R14 165/60R14 165/65R14 175/60R14 185/55R15 195/45R15 195/40R16 i think these will fit
will 195 / 50 / r15 not fit then?
maybe fit maybe not... these are recommendations. if I were you 15x6.5 et 35rims and 195/45-15 tyres.
I just bought tomason tn3 rims but only 14" and new 165/65 barums ;)
The tyre size fitted with the alloys is 205/45Z R17 (tyres included) will theses fit ? PCD 4 x 100
that is really big tyre for aygo. i dont belive that fits
195/35R17 maybe fits i cant tell u that sure.
The tyre size fitted with the alloys is 205/45Z R17 (tyres included) will theses fit? PCD 4 x 100
What's the offset and withc of the rims? Maximum is 7" wide and offset should be between 37 and 42mm.
But in any case, those tyres are WAY too big. The radius is more than an inch more, giving you about 10%
more circumference, thus a -10% deviation on your speedo (it'll read 50mph when you;re doing 55mph!)
You'll allso loose torque, but might gain some more top speed. But I dout if they'll clear...
195/40/17 would be better, but might stil not clear the arches and/or wheel-arms and fuel filler neck...
AFAIK the official maximum value according to Toyota is a 16" @ 7J with a 195/40/16 tyre
If you want to calculate fitting tyres, have a look here: http://www.205gti.com/techtyrecalc.htm
Use 155/65/14 for the stock tyre, then fill in the tyre you're thinking about below.
The Raduis/Diameter/Circumference should be a s close together as possible to keep
your speedo correct and over 195 wide is just not possible without rubbing.
