Hello From Gloster!
Gloster Dave
Hello fellow Aygo owners.
Had mine a year now and very pleased with it, except I keep curbing the wheel trims on the nearside!
I have a tip to offer - might as well do it here:
If you are getting rain or car wash water leaking into the luggage space the problem may be the foam seal around the rear lamp clusters failing. Remove those and clean the body surface under them well.
Now stick closed cells type door draught excluder around the holes, one round should be enough but two will make sure. The tape may try to peel off if you do not get the cluster pressed back on quickly, two people helps here.
Dave
Hello and welcome to TOC.
Good tip you have there.
