Failure Code Po38X
Zlatan Hristozov
Is anyone knows what that code means,tanks
Sorry, that code doesn't exist.
Need more info.
Hello Zlatan, as others have said that exact code does not exist however in case of a mistake here are all the codes starting Po 38#
P0380 Glow Plug/Heater Circuit "A" Malfunction
P0381 Glow Plug/Heater Indicator Circuit Malfunction
P0382 Glow Plug/Heater Circuit "B" Malfunction
P0385 Crankshaft Position Sensor "B" Circuit Malfunction
P0386 Crankshaft Position Sensor "B" Circuit Range/Performance
P0387 Crankshaft Position Sensor "B" Circuit Low Input
P0388 Crankshaft Position Sensor "B" Circuit High Input
P0389 Crankshaft Position Sensor "B" Circuit Intermittent
Hope this may help you, regards .... Pete.
