How To Remove Boot Trim To Replace Bulb
Berti
I have a 2.0 D-4D Avensis Tourer 07 Registered on which I need to replace the rear nearside stop-tail light bulb.
Problem is that I need to remove the rear quarter internal boot trim to provide access to the light unit cluster and I can't see how to do this.
I have successfully removed the trim running across the floor - this sits over the lock receiver. Then it is necessary to remove the corner trim to get at the bulbs. There are two fittings securing this - one a plastic hook which comes away by removing a philips head bolt (so that's out!) but the other is a plastic/metal D-Ring fitting for securing a cargo net and it is this one on which I cannot see any obvious fixing - tho' it will not simply pull away with a hell of a lot of prising .... to the point that I am afraid that anymore force will break the thing!!
Can anyone offer any advice, please?
Cheers
Bertie
I believe that there are removable small panels in the rear corners of the boot released by turning the button. Inside there is a triangular shaped bulb holder which is removed by twisting and pulling it out and down.
Fitter
post-66293-0-33792000-1300708212_thumb.j
Many thanks Fitter - will have another look!
Cheers
Bertie
  • 5 years later...
Old topic, but I dont know how to remove boot light. :(. Do I need to remove all the trims in the boot? Don't see any other option. Thanks.
The light should pop out.use of a thin screw driver or trim tools does it.
When I helped my friend change his rear light bulb, we had to remove a lot of the trim for easier access:-
I am all easy and quick fix, but the T25 estate access door is too small and you can only do by feel.
I used the trim removal tool and it popped out disconnected the cable stuck in bulb and push all back together. Though mines a hatchback?
Thank you.
Now I managed to remove it. I tried from the wrong side first (near the switch) and nearly broke the cover. Then, done from opposite side and it worked. Thanks.
