Hiace Fault Code P1272
Grobes
Hi there.
Started the van up this afternoon when i was out and the engine light stayed on resulting in 'go slow mode'.
I had it plugged in at a local garage which read the fault as
P1272 fuel pressure regulator circuit malfunction.
He reset the codes and the fault remained.
This is a 2002 D4D model powervan Short wheelbase.
What are the likely causes of this fault, and any suspected remedial action ?
Thanks in advance.
  • 4 weeks later...
Hi there.
Thanks in advance.
hello mate
it seems you have comon rail -- so the pressure regulator is a calibrated throttle plug screwed in the rail from one of the edges, but another edge has presure sensor. Firstly check with this pressure sensor el contact with a wire. may be it is dirty giving you a mistery signal to the ECU and on the dashboard. Cheers/Igor
