Does The 2.0 D-4D Have Any Headgasket Issues?
Onelly27
Hi there,
If I was to purchase the 2.0 D-4D, is fair to say that I shouldn't have any Headgasket issues?
Regards
Onelly27
I havn't heard many...although water pump could go bit funny.
But personal experience with MK2 Avensis, no failures so far except driver side hub bearing.
:thumbsup:
117000 miles no problems. Had to change brake pads and put on new tyres recently and grease brake pedal to stop squeak. Service every 10,000 miles (personal choice) and no problems to report
yes they got headgasket problems.i av changed waterpump but still building pressure so i have done dignos ckeck so its possitive.
hi can you tell us what diagnostic tests have you done? and how you identify that they are positive.
just wondering if I can check on mine too.
well i went to the garage and told them that i have changed the water pump but still building pressure and overflowing from over flow pipe.so,basically its emptying the water tank.so.they done diagnostic check on head that comes possitive,that was private diagnostic check.i have booked on with toyota on thursday{31st}.I will let you know whatever they will tell me.
Best of luck. let us know how you get on with it, and how do they run diagnostic for that.
Would appreciate input of others, who know how to keep an eye on it, other than coolant getting low quickly.
Cheers.
Hi there,
Regards
Onelly27
the 1az-fe engine had issues with the head bolts pulling the threads and causing oil leaks to the rear of the engine. but you did not hear it from me....
