Cabin Filter?
trev502000
hi i have just trader my Aygo in for a 2008 Yaris TR 1.3 just checking it over at home an noticed there is no cabin filter installed just a space for one, should there be one installed?
and im also looking for the installation manual for the usb port by the handbrake?
Should be a drawer behind the glovebox with a sort of corrugated filter sheet thing in it (Assuming the Mk2 is similar to the Mk1!)
Just changed mine and my main air filter; Both black with soot and assorted dead insects! :eek:
My 2008/9 Yaris 1.3 tr has no cabin filter .Not fitted from new
Jim Stephenson
As above, most of them dont come with a filter for some reason but the space is there for one.
Mart.
Really?? :eek:
Tha seems odd...
Is the tray for the filter even there or is it just an empty gap?
Maybe Mk2 Yarisesses don't have cabin filters? :unsure:
Mine definitely has one (2010 Mk 2). I moved the cover to check a couple of weeks ago when I had the lower glovebox out to cure even more rattles and creaks!
We've been here many times before. Lets not repeat what's already been covered many times. A quick search will find many threads on this topic.
Some models and some years had them fitted. Many did not. There doesn't see to be any logic in which did and which didn't.
If you haven't got one, you can just buy one and slot it in. There is no "carrier" or "tray", the filter just goes into the hole and hte cover pops back on.
They're abiut £10-£12 from the dealer and about £5 from your local motor factor......
I had the same problem with a 2007 Yaris but managed to get one from Mr T.(nothing listed for 2007)
Part No. 87139-yzz08. :thumbsup:
hi,they come as an extra when new,you can still put a pollen filter in,hope this helps,danny
