Changing Rear Tail Light Bulb
Darius28
Just noticed today that one of the rear tail lights not working, had a quick look, and noticed that i can get access to it ok, but how to take the bulb out? does all lamp unit needs to come out, or is it better to leave this job for Halfords lot to do? :) Thanks
On mine (05 plate hatchback) you open the cover that you've found and unclip the complete plate which holds all the bulbs. I can't remember exactly whereabouts the clips are but from memory there are three. It shouldn't take more than a few minutes to change the bulb.
Hope this helps :)
Thanks. I found 2 clips on mine, one at the top and another at the bottom. not as hard when you know what to look for. the access is bit awkward.
