Grinding Noise Not Knocking
apaykapuy
hello and good day to all.
i hope you can help me what i found out about our yaris about two days ago.
i came out from our car park, did a full left turn, i heard a grinding/clunking noise in front. i thought that was only natural sound. i did the same but full right turn and move the vehicle, again there is this noise.
is there anyone have experienced this problem? any idea what is it?
our car is 1999 t-reg with 74k miles at the moment.
thanks in advance for your reply.
If its definitely grinding, then I'd say it's probably the brake disc grinding against the disc guard behind it. Just push the guard away from the disc and try going full lock again. This has solved my problem :P Give it some when you bend it back though, because it'll just come back if you just give it a small prod.
z-tune-z2,
you are right, problem sorted.
thanks
