Tmo 461 Error
alan100
Hi i have an error code on my auto changer error code 1. Can anyone please offer me advice on how to fix it. Thank you
Welcome to the club. Maybe shcm can help when he looks in :thumbsup:
Hi everyone at the club by the way. In the hand book error 1 means disk is dirty or inserted in wrong but have checked these and still no joy. :angry::angry:
hi mate
is yr transmission automatic or manual ?
cheers/Igor
Not sure I can help much remotely. This is the under-seat changer isn't it?
I assume all the discs are seated properly in the cartridge and the cartridge is loading nicely when you put it in. You can normally hear it checking for the presence of each of the six discs in turn when the cartridge is first loaded.
I expect it won't help, but it might be worth just pulling the wiring connector out under the seat, waiting a few seconds and then re-inserting.
Other than that, If it were me, I'd probably have the thing apart and look at the optical pickup assembly, in the vain hope it is just something simple like muck on the lens. Not everybody wants to or can do that though.
hi mate
cheers/Igor
My transmission is manual. the changer is situated under the passenger seat. I can see it loading in the discs and when you turn it on it gives 3 small ticks then error 1 appears.
hi mate
cheers/Igor
hi mate
it seems I have misunderstood the meaning of "disc" -- I thought you talked about friction discs belong to an auto transmission gear. Sorry mate to be disable to help. Good luck/Igor
