We have bought a UK import Toyota Aygo. It came with one key. We dont even have the key tag with numbers. I found someone to make me a key with immobilizer from original key. I wish to know if the airbag is switched off with same key or a special key.
Same Key! look to the lower right of the steering wheel... there's a red key slot :thumbsup:
I found the slot but excuse my ignorance I tried to turn clockwise and it is spring return and noticed that the ignition key did not go all the way through the airbag slot. I did not want to force before I get instruction from someone in the forum. Thanks.
Ok I found how it works I inserted key, turned anti clockwise and then pulled out key.
