Need Help In Wiring About Abs And Engine System
strif
Hi All ,
i am new at here , nice to meet you all ,
first i come from Malaysia , a rav4 96' owner ,
my stock engine 3SFE was burn out because of the crankshaft bearing ,
i was buy a ST215 caldina front cut , and put in to my rav4 3SGTE .
i had meet some problem on hardware but fix it ,
now i have some wiring problem , need help from everyone , Thanks ~
I am using ST215 Engine and transmission , the ABS was remain stock .
i have some sT215 wiring diagram , but now i meet the problem about ,
should i use ST215 abs system or keep the stock or mix them ?
first , the ST215 abs hardware was not same place on engine bay and i not sure about the socket of wiring of them both ( rav4 and caldina ) are the same ,
second , ST215 have abs & tsc & vsc in a ecu box , but rav4 only have abs
3rd , if i remain the rav4 abs system , is that it need signal from engine ecu / transmission or it can work it alone ?
4th , if i want to remain the stock abs , can i mix them on the wiring ? ( means i use stock ABS ecu or i can make the jumper on the signal from caldina abs ecu ? ) if can mix , how i know about the socket and the signal ( Any1 have the wiring diagram about abs of rav4 and caldina ? )
5th, if i use the caldina stock abs hardware , it was not same position on the engine bay with rav4 stock , same as the brake pipe too . ( i means those brake hose from the vacuum to the ABS separate to 4 brake horse for front 2 wheel and rear 2 wheel ) i have to a big mod of them
any one can give me suggestion about this ? or i have to disable them ? i had this problem about 3 weeks and still can't fix them ><
thanks a lot for helping me
