hi my carina front drivers side brake is sticking on is it an easy job to remmove the pads to try to release the caliper with some wd40
cheers
steve
cheers
steve
Yep, you will need to remove the flexible hose and clamp it so you don't lose fluid. Then remove the two bolts holding the caliper on i think they are twelve mil. Remove the caliper and i would place it in a bucket of wd40 overnight and then see what it's like the next day. Before all this tho i would ensure that the slides are free first (where the 12mm bolts go in) and before removing the flexi hose put a large g cramp on the piston and wind it in to make sure the piston can move. Plenty of them in scrap yards. Hope this helps.
