New Member, Need A Little Help
DaN_G
HI all my names Dan, I bough my SR180 about 3 weeks ago now and im really enjoying it. Got it with only 6300 miles on an 08 plate so i was well chuffed! :yahoo: Just changing a few bits on it at the mo numbers plates as i hate the dealership ones, but i need some help and if anyone can a photo on how to change the fog light bulbs. Ive looked in the book and under the car but i cant see what its showing in the book. All i can see is the plastic clips which ive messed about with before on my MR2 and made a horrible mess of it. So if any one can point me in the right direction would be much appreciated!!
Good choice!
To change the fog light bulb for the front, Sorry I dont have any pictures but its a fairly easy job.
H11 Bulb for the fog lights
Passenger side - remove the plastic cover in the engine bay which has plastic rivets for access, near the Battery you will see a hole behind the left headlamp, if you look into it with a torch you will see the fog light, put your hand through it push the clip in and push down the wire, turn the bulb to remove, put the new bulb in securley
Drivers side - cant be done through the engine bay because the windscreen washer bottle is there, get under the car using 10mm socket remove the 3/4 bolts from the wheel arch until you can get your hand through bit of a squeeze remove the old one and replace.
Hi there and welcome to the club :thumbsup:
www.toyota-tech.eu ,Try this site click on free installation manuals select auris in drop down menu
and download the file its a step by step guide
Hope it helps you
Thanks for that guys nearly started but my bulbs ive got are h3 lucky i didnt take any thing off or i would av been gutted
H3B will fit your high beams (I think) so if they are upgrade bulbs, they might be worth keeping as spares or do a swap.
Na i probably wont keep em there yellow bulbs was going for a more jdm look gonna hav a hunt around seen some piaa on rhdjapan but £45 :wacko:
Ive just replaced my mains for Philips Blue Vision HB3. Very pure white and very bright compared to originals and only £20 for the pair. Also changed dipped beams for Osram Nightbreaker+ H11 and sidelights are now quad LED 501s. All in all, well worth it!
