Vehicle Stability Control
Roker
I have a 2005 Avensis which has ABS & Traction control, does this include VSC (Vehicle Stability Control)? how can I tell?
Look for the VSC light in the dashboard when turning on the ignition.
does it have a manual? I don't know if the light on the dash means it is actually fitted.
If there is a VSC light in the dashboard when turning on the ignition, the car obviously has this installed...
There is no button for turning of VSC on my 2004 Avensis. I only have one for turning of traction control witch is very useful in snowy conditions. I can't imagine anyone having an advantage of turning of VSC.
Correct you cannot turn off the VSC. The light does come on for a couple of seconds when I turn on the ignition, it is located next to the Traction Control light. so it must have it VSC.
