Noisy Yaris Diesel Gearbox
dja
Hi, I have a 2002 1.4 Diesel which has done 170,000miles.(90% motorway miles). The gearbox has always been a little noisy but of late it has got very slowly worse. It's a general wining noise but when I'm stationary and I depress the clutch the noise stops. Gear change is fine and the rest of the car is great. Any clues from anyone. Many thanks.
Hello, I assume you have checked the gearbox oil level or changed it ... apart from that it could be a bearing on the input shaft.
Pete.
Maybe the clutch release bearing on its way out? But I'd start with the gearbox oil to. :thumbsup:
" when I'm stationary and I depress the clutch the noise stops. "
Big clue. Sounds like the gearbox main bearings are on their way out.
As a quickie, change the gearbox oil...
