Gear Selection Problem
GWizz
Hi !
Apologies i'm new to this board, i've done a quick search but can't find any relevant posts.
My problem is i have an Avensis which has just suddenly decided it doesn't want to come out of first gear.
I just cannot move the lever (manual) at all.
Car still starts.
Cables seem ok to me but not sure how to check those.
Anyone with any ideas
Regards
Glenn
Seen a few post on here and would recommend a gearbox oil change. Then try again
Hi !
Car still starts.
Regards
Glenn
Hi Glen and welcome to the forum, try this ... get two people to help by pushing and pulling the car in a rocking motion with the handbrake and engine off whilst you pull on the gear lever to try and get back into neutral.
If this works I would also recommend changing the gearbox oil.
Good luck ... Pete.
Thanks you two i'll certainly give that a try & report back :)
Regards
Glenn
Hi !
Car still starts.
Regards
Glenn
Good luck ... Pete.
