Avensis Engine Cuts
Phil99
I would really appreciate somehelp with a problem which is causing me real concern
I have a 05 plate toyota avensis T spirit, its a 2litre pertol engine. Its started to intermitantly cut out on me when pulling off from junctions, it does start straight away afterwards. I had a similar problem with a Vectra which despite spending considerable sums of money on the problem was never rectified.
Has anybody else experienced this problem and managed to get to the bottom of the problem? Any help would be much appreciated.
I had the same problem on my 03 t spirit until mr t did the recall work on it. Hasn't happened since.
Thanks, to confirm are you referring to the resent recall (fuel pump)? I have already put my car in and it has cut out more regularly than before.
clean the Trottle Body and sensor.
Check the Air Flow sensor.
check air pipe.
Had this work done and car running much better, thank you.
