Preemptive Post - A/c Makes A Humming Noise
Grumpy Cabbie
We've had a few hot days lately and having a black car I've had to have the a/c working quite hard a few times. The car started that loud electrical humming noise when the a/c compressor was running and I thought I'd do a preemptive post for the newbie hybrid owners.
The a/c on the hybrid is electrical and not driven by a belt from the engine. This is an efficient system but it HUMS loudly under initial full load on a hot day. This is normal and nothing to worry about - though alarming the first time you hear it.
Apparantly the a/c system draws 4kw from the HV Battery under full load.
The hotter the day, the harder the a/c works and the louder it can be - but it will die down and is unlikely to be heard in the car.
:thumbsup:
Apparantly the a/c system draws 4kw from the HV battery under full load.
:thumbsup:
Can't hear mine hum, probably because of the road noise round Rotherham :rolleyes:
Just bumping the thread as we've had some hot days and somebody is bound to ask :yes:
Since I just got my Prius, but living in Thailand I was also surprised that the ac made such much noise. If it takes 4kW of power, then that might be the reason that I never had full Battery? Max I got on a 200 km drive was 7 lines.
Mine doesn't hum because it knows the words to the tune :yahoo:
