Brakepads And Discs
qureshi14
Hi, I went to toyota garage free recall upgrade software and checking my breakpads Toyota corolla verso 06. I didn't get the report writtenly. Have any idea how it works upgrade engine software? and Have you any idea about how much it cost to replace the whole discs and break pads? Has anybody any guess or recommondation from anywhere? really appriciate! Thank you
Hiya mate,
A few of us on here have changed our disc and pads to MTEC. They are as cheap as chips and fantasic quality over the original set up. I went for drilled and groved (Black addition) and the stopping on them is just as good as Black Diamond but half the price. They look fantastic as well.
Not sure weather yours is a diesel or not... But this is the kind of price for the discs for a diesel
Toyota Corolla Verso 2.0D-4D 05/04-09/05 Performace Front Rear Brake Discs
Front Discs Specification:
Vented - Studs 5
Disc diameter 295.0mm
Disc thickness 26.0mm
Overall height 49.3mm
Centre diameter 62.0mm
Minimum thickness 24.0mm
Rear Discs Specification:
Solid - Studs 5
Disc diameter 290.0mm
Disc thickness 10.0mm
Overall height 57.0mm
Minimum thickness 8.5mm
£142.51
Freephone: 0800 410 1910
Email: info@mtecbrakes.co.uk
Opening Times:
8am - 6.30pm Monday - Friday
9am - 2pm Saturday
Hi, My car is corolla Verso diesel 2.2. I had non drilled before, so are these suitalbe for these? what 's the difference between drilled and non drilled discs? which are better?
Drilled give better cooling of the discs. and groved help prevent brake fade :thumbsup:
