Outside Air Thermostat
pauljr
Hi
Does anyone know where the outside air temp thermostat is located? Mine has been blank since I bought the car 9 months ago, however after visiting a car wish it came on for about 10 mins showing -30c (it wasn't that cold) before going off again. This makes me think its just the connection needs cleaning. I thought I had found it attached to the front of the rad, but I doubt they would locate it next to a source of heat like that.
PS Its a 2002 GS model.
Hi
the outside temp sensor on my auris is along side the front of the rad,it can be seen through the grill.
so would expect it will be i a simuler place on the avensis.
Hi
The ambient air temperature sensor is behind the front bumper just below the Toyota Badge.
Fitter
Hi
Fitter
+ 1
investigate the area behind the grill -- you'll see a pin type sensor with its signal wire.
cheers/Igor
Thanks for your replies, I'll take a look.
hello mate
time to time one'd clean it enebling it to pass an accurate temperature to the ECU.
FYI - the ECU thinks how to govern the throttle valve (belong to A/C system)to reach desired temperature in the cabin fastly. Cheers/Igor
Do you know where the inside thermostat or sensor is located?
If you have climate control unit, then its located at the top your dashboard near the windscreen.
