Tsport High Lift Cams
Nath_c
Havent posted in a while, but thought this was a interesting one for you T-Sport owners to read...
Bought the latest edition of Bonzai (japanese car tuning mag, for those who don't know) and was reading the most recent performance parts available. Anyway i found a small section for the yaris T-Sport, and JUN performance have released high lift cams with 9mm lift for £300! These have to be imported, but a company does it especially.
The best part of all this is the fact they are direct bolt on, im very interested in these, so thought i would share it.
What do you T-Sport owners think of this?????????????/
  • 9 years later...
Have you seen or used the jun high lift cams and are they worth the money thankyou in advance. James
The topic is 10 years old and the OP hasn't visited the club since July 2011, so you're not likely to receive a reply from them.
Recommend stainless steel exhaust as well and a four branch manifold
it's been a while, since i have played with cams, but you get what you pay for, I have only ever used Piper or Kent cams
You need to get the head ported, polished, flowed, and maybe bigger valves to take advantage of the cams - of course it's all worthless without a remap/standalone ecu - you're not going to get much change out of £2500-4000
Jun are £3-400 each you can get a blank ground to your spec for a bit less
don't bother with reground cams either as it weakens them,
