Rav4 Side Steps/bars
geordie1892
Just bought my first rav4 march 2005 model 5 door and i love it. I would like to fit some side steps/ bars but i want t0o make sure all the pre drilled holes are there first before i buy them. I can find 2 holes on each under side with grometts fitted but thought there would have to be 3. can u help please
thanks geordie
thanks geordie
Hi Geordie and welcome to the club.
There should be three mounting holes each side - see attached PDF :thumbsup:
Side steps 5Dr 4.2.pdf
thanks geordie
You beat me to it Davrav,I was also going to suggest geordie added more info on to his model listing for future questions
Hi Geordie and muchos welcomos to the house of fun....which one can't you find? There's a front, a middle, and a rear one, which is quite close to a rear suspension arm thingy, which makes it a bit more difficult to see and get a spanner on.
Big Kev :thumbsup:
Hello again. I have the rav4 march 2005 xt3 and it seems to be the rear holes i cant find. cheers
Covered/bunged up with underbody protection coating/gunge or mud maybe :unsure:
Sorry for being a pain but i just cant locate the whole on the underside towards the rear. the front and middle have a gromit over the hole. there are 3 holes on the underside behind cill with gromits on but there is no place for a hole on the underside of the floor at the rear if that makes sense. rav4 xt3 5 door march 2005
They're the ones I think you need - do they match the spacing of the holes in the suspension profiles? There should be M8 threaded holes/captive nuts, if you pull out the rubber plugs/grommets, to take the longer bolts [numbered 19 in the PDF illustrations]
Let us know how you get on :thumbsup:
