Rattle Underneath
andrewfq
32 minutes ago, tafia14 said:
Dealer charged £60 to fix it.
Probably under one hours labour.
  • 4 weeks later...
2 Years after we fixed ours by just adding a bigger washer and there is still no problem. Ther rattling nature of the Auris is doing that. Here I know of 3 more Auris diesels that had the same problem and the same fix - bigger washer on the screw that is holding the heatguard.
  • 4 weeks later...
On 05/01/2012 at 11:39 PM, UnReaLT said:
I had a similar problem with my 2.0 D-4D, nothing a few cable ties can't fix...
Can't you just bend it back into position away from what it rattles against heat shields are common for this noise and just need re bent or cable tied as other member says
Insadi1,
Thanks for your responses. As mentioned above the shield has been replaced now. It is right next to the fuel tank so needs to be right.
Best,
T
