Carina Coolant Loss
sconnochie
since my last post regarding foaming coolant I have replace the thermostat and tried to purge the system of any air locks.No change, however I have just noticed water seeping from the front pully area, cant investigate further as I am at work. Still geting streams of small bubbles through the coolant while the engine idles(all temperatures). Could I be drawing air at the water pump and dropping coolant? Or is looking more likely that the coolant system is getting pressurised from the cylinder head and has blown the pump seal?
