Celica Gen 6 Rear Brakes Keep Binding
littlekev
I have a Celica 1.8st Gen 6, it's Rear Brakes keep binding - I could do with some advice please.
at fault at the moment is the drivers side rear, I've had the brake pads off and the wheel still seems to bind!
over the last 2 years i've had the callipers discs and brake pads replaced by a local garage at silly costs, it seems to fix it for a while but after a bit it goes again!
I wouldn't mind but I only put about 2000 miles on the car a year if that!
any advice would be appreciated please.
Many Thanks,
Kev
Lancaster Lancashire
are you sure its the rear calipers at fault and not the hand brake - which is totally separate on the gen 6 set up.
i'd be guessing that the hand brake cables are stretched.
