Sr180/t180 Sunroof Problem
Andy SR180
Hi
My sunroof started to play up a bit about 6 weeks ago. Then seemed to sort itself !
However as the warranty is nearly up I took it to the dealer as asked them to check it out, they told
me they can find no issue fair enough.
But, when it is closed at you hit tilt to goes up a level, then if you press it again I am sure it opened/tilted further, the dealer are saying it only goes one level on tilt, and they didn't have any other auris' with a sunroof to check.
Can someone advise me or am I dreaming ??
thanks
Andy
Not the same fault as I had on mine but ToyotaGB tried to tell me they dont get Auris's with sunroof issues so stick to your guns
Andy in 2 years with our T180 we only ever had one step up on tilt but on slide open the roof had 2 steps / positions
On tilt, one step only.
On slide is actually fully adjustable depending on when you let go of the switch, but to let it do auto (hold switch) there are indeed 2 steps.
