alright its been a long wait but any day now i should recieve my 5e-fhe engine..
for my starlet.. :rolleyes:
ive got a six speed box ready to mate to the enigne..
im looking for some used parts to fit at the same time as the engine transplant.
this list includes a :help:
lightend fly wheel..(trd one on eBay for a ton..just missed it :ffs: )
uprated clutch in decent nick
shorter drive pully
and a throttle body off a gt turbo..
mr2 calipers &
lugs off a 4WD Hiace
rear glanza strut brace
i know its a stab in the dark and i will get these parts in time but if anyone could help me with these parts id appreceate it..
im stuck to a budget.
also whats the cheapest and best way to import a front anti role bar from whiteline in ausland. thanking in anticipaition. :ph34r:
Personally I wouldn't go with an underdrive pulley as it won't have the damping system that the Toyota one has. Your flywheel could be machined slightly to reduce weight.
Your clutch plate could be relined with a uprated material (cheapest)
The rest I would do in stages. When modifying a car the biggest problem you can have is to change too many things at once. If you do it in stages you will find out what works and what doesn't work which may not seem important but would make sense over the long term, and also help other people who want to copy you.
Andrew
hopefully i should have mine on saturday and then get her fitted this weekend!! the race is on lol
Where you guys gettin the engines from and who's fitting them for you?
Im very interested in this conversion... was gonna do the 4E-FTE but it will cost too much :|
I've got a 5E-FHE engine for geocool69
I know it not the question in hand but how did you get your sr so low geocool69. I've fitted apex springs and kyb shocks but it's still high. Do you think fitting koni adjustables will help. Toby
fitting different shoks wont make a difference to your ride hight
u need to ither get different lowering springs or some coilovers. to go low..
have u any pics of your car
I don't at the moment coz im at uni. it looks pretty much the same to yours except my sppedlines have been painted brilliant white. I thought painting them black would make them look like steels but they look well nice. toby. What shocks are using and springs?
