Connectors Under Driver And Passenger Seats ?
cdrikdrikc
On my toyota auris 2007 Luna with an leather option...
I just seen that there was 2 connectors unconnected, one under each seat (driver and passenger), between 2 and 4 pins I guess...
So, the question is, what is it for ???? heating, Speakers ???
Pronostics
Estimated guess:
Airbags
Seatbelts
Heated seats
Speaker wire
If its not connected perhaps it shouldnt be because you dont have the option to use what ever it is for, most manufacturers have the car wired up so if a customer requested for example heated seats its a simple install because its ready like plug & play...
Speakers' connectors can be found only inside the doors, not under the the seats; those unconnected connectors are there for heated seats, almost sure.
Ok thanks both,
So i could find some second hand heaters to heat my leather seats ???
just to connect to those connectors ?
Ok thanks both,
i should think the heater elements are built into the seats,so would need seats replacing.
dont know this as a fact though.
Ok thanks both,
You're welcome !
You can fit some second hand heaters , first identify the switch connector that can be found under the central console storage box, (it's a black colour 8 pin connector, I'll tell you terminals signification), then remove the seats upholstery, put and connect the heaters to designated plugs; finally, put a 10 or 15 amps fuse (fuse no.11 inside the fuse box).
