4.3 Glovebox Illumination
Davrav
Finally got round to sorting out some illumination for the glovebox on my 4.3
I used:
Maplin N86CZ self adhesive yellow LED strip [2 x 3LED sections @ £1.04 per section]
Glovebox lighting loom from a 440 series Volvo - £2 from scrappy [i woz robbed :angry: ]
Piece of 2mm styrene sheet - had that already
4 spade connectors - had them too
3 self adhesive cable clips and two small stainless self tappers - had them as well :thumbsup:
I decided to use the upper lip of the glovebox surround to mount the LEDs as it seems to be in a convenient position when open. I took a feed from the cigarette lighter illumination. I could have tapped into the footwell LEDs as an alternative.
First step was to make up a mounting strip for the LEDs
I cut a 125mm x 18mm strip from 2mm styrene sheet, shaped and drilled it, dimensions as per diagram in attached PDF. I scraped a groove between the strain holes so the wires sat slightly lower
NB - the 5mm holes marked on the PDF are for the drilling jig only - no need to drill these in the mounting strip.
Next I mounted LED strip and threaded wires through - my LEDs were first off a new roll so had connecting wire already soldered on DSCN2644-1.jpg
Note the 'strain relief' holes and threading
I then added the spade connectors
I soldered them on and packed the shroud with silicone for added strength as the wires were fine gauge
On checking for fit at the chosen mounting position I found I needed to cut a shallow recess to accommodate a moulding web on the back of the lip
Then I removed the glovebox as per first two instructions HERE
Next I needed to make a drilling jig from sheet metal to ensure LED apertures and fixing holes were in alignment
Clamped jig in place
Checked alignment and drilled the 5mm LED apertures, checking alignment as I progressed
Next was the fixing hole positions - I used a 2mm drill through the jig
These were then opened out to 3mm clearance size for the small self tappers I used, then countersunk to take the heads
I found the plastic to be quite soft and 'wooly' and had to carefully clean up the holes with a scalpel.
Then I placed the the lED strip on to top side of lip and screwed into place with the LEDs sitting in the apertures. The LEDs are about 2x3mm and stand about 1mm proud of the tape they are attached to and, with the plastic lip being about 1.5mm thick, they do not protrude.
Whilst working in the glovebox I drilled the 8mm hole for the switch. I used a woodworking spur bit to avoid slippage.
and then fed the wires through and push fitted the switch to check for fit.
Could have been 5mm higher on reflection :unsure:
Next job was to gain access to the feed wiring - this was achieved by first removing the console side trims
Lever up with a trim tool or similar and pull up and rearwards to remove.
Gearstick moulding was lifted out of the way too
Then I had to unscrew the cupholder/switch panel
and unplug the two connectors. The one I needed was grey with the dark green wire having +12V
At this stage I offered up the loom for sizing, trimmed the switch wires and soldered on two new spade connectors to suit
New connectors are the red ones.
I fed the loom through from the switch and decided to dismantle the plug and solder direct to the terminals but 'Scotchloks' would have been far quicker. I labelled the plug to avoid making an error when re-assembling :unsure:
Once that was done it was a case of connect up the LED strip, test, use the self adhesive cable clips to tidy away the wires [i mounted them on the underside of the upper storage section] re-assembled and had a beer :cheers:
I spent a lot of time working out 'how to' but I guess actual work time about 2 hrs give or take :unsure:
Here's what it looks like in the dark - you 'have to be there' to get the full effect :lol:
Glovebox LED light mounting PDF.pdf
.....and you can find this excellent tutorial pinned in the maintenance and tips section - thanks Davrav :thumbsup:
Sincere complimentarianisms, Davrav....don't forget your tools when you come up now, y'hear...????
Dark Kompartment Kev :lol:
He'll take all the credit for it Dave!
I was just wondering what he was impressed with - the work or the fact that it cost next to nothing :lol:
And all this after the amount of calls I received from Davrav...."how should I do this / that / the other Kev" whilst he was "doing" this mod....AND the calls were reverse charge. Gratitude....
Big Kev :unsure:
  • 5 months later...
done guys!
i have done it with the components from austrian www.conrad.at B)
8 LED strip (3.50eur)
http://www.conrad.de/ce/de/product/187777/LED-STREIFEN-PLAT-330-MM-12V-WARM-WEISS/0212015&ref=list
door switch 1 Eur
http://www.conrad.de/ce/de/product/705012/MINIATUR-DRUCKTASTER-ROT-TYP-A-SCHLIEssER/?ref=reco
one more spring washer under the door switch to have it on right position. i have made the switch shorter by removing the cap and cutting the end.
the LED strip is fixed by 3x plastic cable fasteners (2x 3mm holes for each).
the result is here:
thanks for sharing the know-how!!! great thing, its really a must do!!! :thumbsup:
This is a great mod, and beautifully executed, I especially like the drilling jig. Gives me an idea to do my own!
