Tail Light Cover By Warranty
t43er
Hi guys, just noticed one of my yaris's reverse light bulbs is not functioning. So just wondering whether it's covered by the warranty?
I've opened up the cover and had a quick look. It doesn't look diffucult to me to replace it but if they are covered then I will not mess with it. Also recommendations on where to get the bulbs will be useful! It's a 06reg yaris tspirit fyi.
Thanks a lot!
There is only one reverse light. Its on the nearside. The rear fog light is in the same place on the offside.
And no - bulbs aren't coevred by warranty. They are a "normal wear and tear" item....
RIght had a quick look on the evilbay and 2 options came up. The conventional light bulbs and led. I know led is suppose to be better but any opinions regarding them? Insurance or legal wise?
Or I should just stick with the normal ones?
Would be easier for you just to pop into your local car accessory shop or even Halfords. They will sort you out with what you need for sure, but I believe it's this one (please check for yourself)
http://www.halfords.com/webapp/wcs/stores/servlet/product_storeId_10001_catalogId_10151_productId_212793_langId_-1_categoryId_165538
You didn't read my post properly - there is only one reverse light on the Yaris. If one is working then its fine! There aren't two revfersing lights.
Its common with many cars these days, the reverse light is a single light on the near side and the rear fog light is a single light on the offside in the same place.
Thanks for the reply Hartside.
I got your msg alfiejts. I really appreciate it. However I just want to know whether those led ones are good? Just for my knowledge really.
