Speaker Installement ?
egotrip
Hey !
Just bought myself a Toyota Carina E 93mod.
I've installed new Speakers in the front doors wich was very easy .. but When I got to the back doors I stumbeled onto a problem ... how do I remove the Manual Window raiser thingy ??
Any of you guys/girls know how to to it ? :]
My Old Saab 99 76mod. I didn't have that problem
Thanks in advance :]
/E
I use a strip of rag about 12" x 4". Twist it lengthways (4/5 times) to make a length of 'cord'.
Next, turn the window winder so that it is vertical with the handle downwards.
Hold the rag in a 'U' shape around the winder spindle, so that its between the handle and door trim, one end of the rag in your left hand, the other in your right.
Then, pull both ends upwards, in a left/right motion.
This should make the clip pop off.
To replace, firstly place the clip on the recess on the winder, then push the winder onto the spindle - it will click when in position
