Rav 4 1995
DAWNYLOU68
HI THERE
I am a newbie with a problem and hope you can help?
my electric window on the driver side has stopped working and wonder what part i need
Also where do i find the fuse for central locking?
many thnaks dawny
Well, its a welcome frae me and a gruvellin apology for no replying afore the noo. I did see yer post an meant tae look oot ma manual...then tripped over the ither pile o papers I have...
I'm guessing abit, but yer central locking is wired into the fuse block down at the passenger footwell from memory. Behind an easily removed plastic shroud - just check all the fuses. The alarm system on these cars weren't too clever and it may be that yer fob Battery has expired or that the system has expired.
Electric window - well theres another fuse block near the drivers feet so check the fuses there as well. I've found the windows to be reliable, although sometimes a bit screechy.
I'm guessing abit, but yer central locking is wired into the fuse block down at the passenger footwell from memory. Behind an easily removed plastic shroud - just check all the fuses. The alarm system on these cars weren't too clever and it may be that yer fob battery has expired or that the system has expired.
thanks i have bought the manual but no help, i have ordered a new switch now found one on eBay but found only a fusebox near knee on drivers side and one under bonnet. we will have alook in the other places you mentioned. many thanks for replying :))
Theres probably a fuse box behind the plastic shroud to the left of the passengers feet. Well, there is on mines (plural note !) And theres another wiring block behind the plastic shroud to the right of the drivers feet.....can't remember if theres fuses there but I'll know in a days time when I rip the dashboard out.
