Which Oil?
paul121
Oil is a very emotive subject as you can see here on this recent thread
http://www.toyotaown...pic=107451&st=0
5w 30 semi synthetic, from any well known manufacturer will be OK, your dealer will sell it at a good price too. The spec of the dealer oil is 5w 30 API SL ACEA A1/B1
They also do a fuel efficient version 5w 30 which is API CF; ACEA A5/B5 C2
The choice is yours :yes:
Kingo :thumbsup:
I have a couple of 4 litre containers of Castrol GTX Magnatec 5w30 Fully synthetic . Im assuming this will be OK for the 2.2 T180 Diesel engine ?? Thanks.
Charlie,
Charlie,
What you have to look out for is the C2 spec for the T-180 for the D-CAT. Mobil 1 ESP 5w-30 meets this spect but oils like Castrol EDGE does not even though they both meet the VW 507 00 standards. I would not use a semi synth as you've no idea to what synth oil is in it. Could be 70% could be 10%. The only way to get the best oil is go for a full syth or better still an Ester oil but you'll pay a lot for it...
Charlie,
Mate Im confused ?? The Oil I have is Fully synthetic !!! Castrol GTX Magnatec 5W30 .......??????
Charlie,
But does it meet the C2 spec? I think you'll find that the Castrol Magnatec pro is a C2 spec. But that can only be bought through the trade...
Not sure Mate I will have to look into it !! Will it state this on the tub ?? Or should I say Tubs as I have 6 brand new unopened tubs of the stuff ...................... :rolleyes:
Your magnatec meets the specification laid out by Toyota for that engine :thumbsup:
It will have a spec list on the back of the tub. If Anch's says it meets the standards then it will. :thumbsup:
Says on the containers
SAE 5W30 AP ISL,ILSAC GF-3,
ACEA A1/B1,A5/B5,
Meets Ford WSS-M2C913-A
WSS-M2C913-B
WSS-M2C-913-C
Whatever the fiik that lot means ..........................
