At the bottom of the auto transmission indicator on the dash, there is a new light that wnt on that says "PWR" in green. What is this?
There should be a switch around the shifter area that says pwr and econ or nml.This just changes the shift points in the transmission.If you move the switch to the other position the dash light should change accordingly.
:thumbsup:
Got it! Thanks very much!
Callie
