Sat Nav Disc ?
CharlieFarlie
Thanks - so who's biting the bullet and trying one?
Is it possible to get the E12 update discs? Where and how much?
These must be origional or very close to, as I know for a fact that the E13 discs which are being offered, cannot be copied at present. If these work, then you cant go wrong really for £40,
Does it have E10 ,E11, etc written on it? ( or is the disc a copy like mine was when I bought the rav :-()
86271-60w394A or the like?
can you upload a picture of your sat nav unit.
Will need the correct make and model to save you time and effort, as downloading 8GB is very time consuming, espesially when you have downloaded the wrong DVD :crybaby:
any of these look familiar? Click on get map and then choose your vehicle, then select the sat nav which looks like yours.
http://www.toyota-mapupdates.eu/
Mate I've found it and imputed the disc number.. The one on offer is version ten at 157 euros or £141 somehow 39 quid has a better ring to it !!!!
the £141 will be for the full 4 dvd set will it not? so works out cheaper if you had to buy the 4 dvds?
Topic closed
TOC does not condone copyright theft however you want to try and justify it.
This topic is now closed to further replies.
