185 Gt4 Turbo Actuator Issues
mistyangel
evening all
my actuator is causing problems , its only allowing boost of 0.3 bar , engine management light is also been triggered under boost , however that goes out when i ease off the boot ... will the mr2 turbo actuator fit the 185 turbo ? if not any suggestions where i could source an actuator to suit this car, trying to avoid the main stealers if i can, appreciate any advice, thanks.
evening all
check your error codes mate, mine done the same thing when it over boosted and hit fuel cut wouldnt let me get boost untill i disconected the Battery and connected it again
I'd check your error codes then look for boost leaks.
Any MR2 or GT4 actuator will fit or get an after market adjustable one
