Avensis D4D T-Spirit
blitzchaser
Can any one help on this problem!!! My lights dims and heads are not working right, i fitted a cheap h7 HID kit off eBay they worked for a few weeks until one light stopped working i removed the kit put in all new halagon bulbs back in. the dims are not working right low light from dims head lights are slightly on when i turn on the head lights the dims go off with only one head light working. There is no wires cut or loose connections i think it is a canbus problem. Its a 05 avensis d4d t-spirit!! very thankfull for any help....
Moved from new member introduction topic
Can any one help on this problem!!! My lights dims and heads are not working right, i fitted a cheap h7 hid kit off ebay they worked for a few weeks until one light stopped working i removed the kit put in all new halagon bulbs back in. the dims are not working right low light from dims head lights are slightly on when i turn on the head lights the dims go off with only one head light working. There is no wires cut or loose connections i think it is a canbus problem. Its a 05 avensis d4d t-spirit!! very thankfull for any help....
Try disconnecting the Battery for 15 minutes and start from normal halogen bubls. Once you regain normal beam, then get reasonable canbus error free HID ballast.
I have recently fixed HID kit, and its working brilliantly.
thanks very much i'll give it a try cheers!!
