It will have the larger 225cc injectors compared to standard paseo and different cams.
However as this engine has a bottom end failure, I would have doubts over the integrity of the top end as these engines normally fail due to blocked oil pickup or running out of oil, and the cams may be damaged as may the pistons.
I've got 3 dead Sera engines as well...
