Avenis 1.8 Gls 1999
adecbr929
Hi There
Could anybody help with the following,at least once or maybe twice a week my alarm will go off without any reason,i cannot find anything which is obvious,anybody got any ideas????..
Many thanks
Ade
No doubt you will know that alarms work on a voltage drop, have you noticed when it goes off if there is a heavy due or its been damp ? This in my opinion would indicate a poor earth plus have you had the Battery checked for a cell going down or in need of a new one.
If its an intermittent i would suggest having the Battery checked first, maybe someone else could offer a different reason to your problem.
No doubt you will know that alarms work on a voltage drop, have you noticed when it goes off if there is a heavy due or its been damp ? This in my opinion would indicate a poor earth plus have you had the battery checked for a cell going down or in need of a new one.
If its an intermittent i would suggest having the battery checked first, maybe someone else could offer a different reason to your problem.
Hi
Many thanks- i think its worth getting the Battery checked 1st
Cheers
Ade
My alarm went off due to the Battery being low, during the cold snap at the beginning of the year. The car could not start!
I had not used it for a few days either.
I topped up the cells with distilled water.
The car is fine since.
Just think of the alarm acting as a low Battery warning.
I agree with Pat2u to check other items.
