Buying And Adding New Keys
grand4
hi all,
I have a few questions for you to help save my head. Last week, I lost the only spare key of my wife's YARIS D4D built in April 2004.
We only have a black key left with the remote fob in it that opens the doors but does not lock them. Probably, a button is screwed.
- I have bought on eBay from an English seller a separate fob (RS 3200 model/see pic) but cannot be sure it works: any hints?
should I buy the exact same model as the flawed one? At the T. dealership they said it's a 50/50 challenge..
- I would like to buy an uncut black (w/o fob) key, have it cut and recognized by the immobilizer:
what model should I buy especially concerning the included transponder chip? I have read that it may be 4A or 4D.
The blade is a TOY43. I have read that some locksmiths can cut the key directly from the VIN.
- can I delete the lost key for the lot authorized to start the engine or should I go to the Toyota dealership to have this done?
I bought last year (July 2010) a D4D MMT with only 2 black keys. Is the procedure different from the previous one?
Thank you in advvance for your answers.
pierre (french guy)
post-108665-0-66574900-1304873338_thumb.
http://www.toyotaownersclub.com/forums/index.php?showtopic=113030&st=0&p=1023460#entry1023460
Here is the link for the programming,
INSTRUCTIONS
Programming Remote Key Fob
Drivers door open and removed from ignition
Insert key into ignition, then remove it
within 40 sec close and open drivers door twice
inset key in ignition then remove
close drivers door
switch ignition ON and OFF once to program new key code whilst retaining original codes or twice to program a new key code whilst erasing the original codes
Remove key
System should now lock and unlock vehicle, once or twice depending which mode has been selected
Carry out the following within 20 sec
Yaris built in Japan and yaris verso: Simultaneously press and hold key lock and unlock buttons for 1-1.5 sec
Yaris built in France Press key lock button for a minimum of 1 sec and release
Within 3 seconds
To exit programming mode, open the drivers door
NOTE :if system locks and unlocks vehicle twice, programming procedure has not been completed .Repeat button procedure
Adding A Key To The Immobiliser System
Using a black key you have that is already programmed to the immobiliser:
Insert already programmed black key into ignition switch
Within 15 seconds: Press and release accelerator pedal 5 times.
Within 20 seconds: Press and release brake pedal 6 times.
Remove black key.
Within 10 seconds: Insert the new black key to be programmed into ignition switch.
Within 10 seconds: Press and release accelerator pedal once.
Security warning lamp will flash.
After 1 minute security warning lamp will stop flashing.
If programming another key:
Within 10 seconds: Insert black key to be programmed into ignition switch.
TO EXIT PROGRAMMING MODE: REMOVE IGNITION KEY AND PRESS BRAKE PEDAL AT LEAST ONCE WITHIN 10 SECONDS, OR WAIT 10 SECONDS.
NOTE: A MAXIMUM OF 7 BLACK KEYS CAN BE PROGRAMMED.
Hope that helps you!
Nick
An alternative for emergencies:
Lost keys; Programming from scratch - http://www.toyotaownersclub.com/forums/index.php?showtopic=110959&st=0&p=1005708#entry1005708
Hi, If it doesn't look like the key remote you have don't buy it, That picture looks like a remote from a old type corolla, and wont work, If you still have the black key you can tune in a new key, With the gray key you can't.
