More Power
mjw 1701
Can anybody advise me on changing my turbo boost from .9 bar to possibly 1.2 without fitting an eletronic boost controller, and can it be done without fitting a fuel cut defencer
im looking for an increase in power without spending to much money or risking the engine going pop.
I assume you have an ST205. You need a relief valve or a bleed valve - but the first is better, they can be had for around £25 they hook upto the actuator, you'll need to disable the Turbo VSV aswell.
At 1.2 bar you should be OK with regards to fuel-cut as you have maps to 1.2-1.3 bar. With boost spikes you might find yourself hitting it occasionally.
I would seriously think about running 1.2 bar however - You want an increase in power - you don't want the engine to go pop. At 1.2 bar with no other modifications and crude boost control (relief valve) I believe you are on shakey ground. I would go for 1.05 possibly 1.1 bar as a limit. I wouldn't go past that without some extra cooling (water injection for example).
Hope this is of use. :)
