Anyone got a clue how to wire up led door pins??
At what time do they need to light up?
when locked preferably
That might prove more difficult than you'd like, as you need to find a signal that lets you
"know" the door's locked and you need to run wiring from the body into the doors.
The central locking control is in the kick panel in the drivers footwell.
There are two rows of pins. cant remember which two pins they are but with a multimeter you could find them quickly. there is a locked and un-locked wire and these go high to 5 vols dependent on the state of the central locking. the leds can be wired to theser with the correct value resistor.
The switch inside the drivers door switches to GROUND.
If you wire the LED to +12V with a series-resistor of about 1k and wire the negative wire to the
orange wire in the kick-panel (I think it's orange) I expect the LED to only light with the doors locked.
But this switch is ONLY available in the drivers door...
  • Topics
  • Our picks
        • Like
        • Like
        • Thanks
        • Like
