Power Lose Problems While Going Uphill On Motorway Esp 5Th Gear
fezi
Please help please help
Hi
i drive yaris D4D 1.4 2002 has done 111000 miles i was very happy with this car till 100000 mile but after that start having problems got it chk by three different places one said temp sencer bought that from toyota and that didnt fix my prob 2end time change the theromostart still the same satuation now i am going to tell u the problem i have noticed few months ago while i was going through normels chk that coolent bottle is full some water mark out side chk radiator was less water but only about a one glass and in those days i was finding the car a bit slagish on motorway while going uphill esp 5th gear some time car come down to 50 and i had to change the gear to 4 and rev counter wont go more then 3000rpm but no problem on normel road and then took it to 3rd place he said change the clutch so i did but prob still the same. HELP HELP HELP
Hi
hi mate
power loss possible reasons:
- engine air filter clogging;
- fuel filter clogging;
- turbo (if it is fitted);
- incorrect injection timing;
- poor injection due to worn down nozzles;
- gas pressure leak (valves; gasket etc)
- EGR valve
check with above and revert
cheers/Igor
Has your car been regularly serviced? ANd if so, by whom.?
Ther are LOTS of things that could be at fault..see above - and all we are doing is guessing..
You are most likely to have a blown head gasket - any water loss?
or a choked up EGR valve - which is easy to solve (clean it - guides on the forum).
or a choked up exhasut system - damaged/carbon build up.
Worn injectors/fuel pump /turbo are rare.
Has the fuel filter been changed? If not in the last 40k miles, it may be blocked and give a loss of power under load or high revs.
Check the EGR valve and give it a clean also its worth taking the throttle body off as that is where the egr gasses come out and it gets blocked. If it is blocked it may not even be apparent there is a hole but have a prod around and you will find it near the bottom under the butterfly valve. The torque settings for the EGR valve and the throttle body are 20nm. If its not that or the air filter or fuel filter check the turbo, i doubt its the injectors because they either work or they don't unless its an intermitant electrical fault. Good Luck
Hi
hi mate
- EGR valve
cheers/Igor
Hi
1 air filter been changed last week
fuel filter has been changed about 4000 miles back
this car has got the turbo but no idia is it some thing wrong with it
injection timing no one fiddle with it
egr valve has been clean last week
and now we left with it poor injection and gas pressure leak mean head gasket but car runns very good on slow speed mean local
plz think again and let me know
put a can of bg244 in diesel tank and see how it goes this will give your injectors and egr a good clean....
Hi
hi mate
- EGR valve
cheers/Igor
Hi
hello again
there are so many mysteries but check with injection quality and try to shift on 4th on the same uphill spot and revert. As you know we can only guess what goes wrong, but basing on the millage covered -- I presume it is right time to inspect injectors and calibrate them on the fuel stand. Just send us an up-dates with your investigations. Cheers/Igor
Hi
as all my friend said there is many things but what happen today i am going to explain i was travelling on the same motorway notice temp light start flashing i pulled up and rang AA he said there is water loss through expansion bottle and did the pr test said engine is fine but that only happen when i was going uphill on motorway for about 2 to3 miles now i am in maze should i take it to Toyota and explain
Check your radiator has all its fins and they have not corroded away.. which could account for overheating.
It could be : a faulty water pump (unlikely), a corroded cooling system (any rust in coolant?) , a slipping drive belt (you would hear it squeal.. does it when the engine starts?), or a failing head gasket.. (if so, a coolant test should show it).
thanks for all the help last thing now for the coolent test do i need to take the coolent sample or drive the car to the toyota or i can get it test any other place
Hi Fezi,
I have the exact same problem, Just got ripped off and had to replace the head Gasket and water pump. Had a full service also but not well down on power above 3000rpm especially up hills. Did you find the problem in the end?
