Key Body Replacement
Clive Capel
Does anyone know of a reliable supplier of Toyota key bodies, local to the Surrey area? We have the metal bit of the key, and the key works electronically, but the plastic body of the key has cracked after 8 years use and the metal bit no longer stays in place. Curries at Isleworth could hardly be bothered to answer my enquiry, but just said we would need two new keys at '£80 or £90 each plus VAT.' I just wondered if there was any possibility of obtaining the key bodies rather than having to go to the dealer (with passport and registration docs etc) and may them nearly £200 for the pleasure! Thanks.
Clive - this has just happened to my wife's RAV 4 and i obtained an uncut key and fob from eBay for less than £5 and had it cut at a general key cutting store for £2.5. If you buy from eBay, ensure that the actual key stem is the same design and for speed that they post from the UK not China. This is the vendor I used http://cgi.ebay.co.uk/2-BUTTON-REMOTE-KEY-CASE-UNCUT-KEY-BLADE-TOYOTAS-/230547323716#ht_4845wt_989
Hope it works out
Regards
dave
  • Topics
  • Our picks
        • Like
        • Thanks
        • Like
