Yaris Help Please
gongie
Hi all, kinda new to this but thanks in advance for any help
I have a 2000 toyota yaris 1.0 petrol. It drives fine but wont idle proberly.
I had it checked on a code reader and said random cylinder misfire and gave
a seperate code for each cylinder misfire. cleared codes and fitted new plugs (denso)
and even tried swapping a new coil through all the cylinders, but no good.
I was told that injectors gave trouble so fitted 2nd hand injectors (4 of) and still
no good. Now after driving i have no fault codes but still missfiring at idel.
Only think is when we check on the computer it has a missifre counter and after
running for about 5 mins this is up to over 200
If anyone can help please
thanks again in advance
put a can of bg44 petrol injector cleaner in and see how you go this is pro stuff!!!!
