Cooling Pump (2.0 Vvt-I)
igormus
Hi Guys
I ve disclosed a minor leak traces -- is pump repairable or considered as normal consumable? (reached 60k kms service time)
Cheers/Igor
Morning Sir. In my experience the pump is to be replaced.
It must be many years ago when water pumps could be repaired.
ok clear now -- will substitute it then -- no way back
cheers/Igor
Even the pump on one of my ancient 1994 RAVs had to be replaced.... good news is that alloy and aluminium and steel are all worth more as scrap metal !!
yes the local foundry will be happy to have a piece of AL :D
cheers
I had mine done 3 years ago. £91.05 for the pump , £47.65 for the belt , £27.12 for coolant! and £112.47 for fitting. Don't know how much Mr T charges in the Ukraine. Interestingly mine had done 36k miles which is 60k kms.
Hi
MrT has charged usd 200 (all in) -- i caught their discount program today with 15% discount for spare and 10% discount for labour. Ok new pump was installed. I ve seen the pump has a mechanical seal that seemed to be leaky. As visible the pump lifetime is around 60k. Now i am inclined to try to repair this pump having changed the graphite gland -- nothing to lose. Will report how i will get on. It is worth to try. Cheers/Igor
